Map and Radix
Old Apr 4, 2007 | 11:17 AM
Breeze's Avatar
11 Second Truck Club
Default Map and Radix
Damn installing a 2 bar Map Sensor on a Radix is a PITA Does anyone have how to tips and is this the correct part# for a Gm 2 bar Map 12580698
Thanks in advance for youre help.
Old Apr 4, 2007 | 11:37 AM
Whippled 496's Avatar
Sorry about the PITA, but mine was a "Breeze" to instal (no pun intended). Popped the connector off, pulled the sensor out, pushed the new one in, put the connector back on, and tuned it up. Of course I dont have a radix like you, just a stock manifold.That part number is the one I used and had no problems. If you want or need any help setting it up, let me know, I have been tuning mine for a few months now.
Old Apr 4, 2007 | 12:30 PM
thunder550's Avatar
High on diesel fumes
Mine was easy too with the Radix...what are you having problems with? I think it took me about 10 minutes. There's an allen bolt you have to remove, then a small bracket, then the sensor pops out. Install new one, reinstall bracket, replace allen bolt, and calibrate the sensor with your tuning software.
Old Apr 4, 2007 | 12:33 PM
dewmanshu's Avatar
Moderately Differentiated
Speaking of which...just how are you doing this? Do you plan to "pop" the 2bar in and drive to F-Body?
Old Apr 4, 2007 | 12:44 PM
Breeze's Avatar
Its so damn hard to get to it and then to turn the allen wrench, and no I wanted to get it ready to do so when I go to F-body central I can switch it over real quick and install the new plugs which are fairly easy then we can Dyno it.
Old Apr 4, 2007 | 01:19 PM
thunder550's Avatar
I don't remember it being that difficult. I think I moved some of the vacuum hoses out of the way and came at it from the driver's side...
Old Apr 4, 2007 | 03:04 PM
We are still talking about the MAP sensor ......right?
Old Apr 4, 2007 | 03:35 PM
thunder550's Avatar
What's a MAP sensor?
Old Apr 5, 2007 | 11:59 AM
Holty's Avatar
Notorious BIG
GM P/N: 12580698
AC Delco: 213-1631
yep, you got the right part number
calsdad
Jun 14, 2023 11:07 PM
legerwn
56
Nov 15, 2015 10:21 PM
chopperloco
Sep 28, 2015 08:40 AM
bagged7104SS
Sep 24, 2015 08:42 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
