manifold supporting.
Old Aug 2, 2009 | 02:33 PM
TURBHOE's Avatar
Default manifold supporting.
i need help trying to figure out how to support my turbo manifold. it cracked again. i found it cracked the other day, so i welded it up. i only got to drive it about 2 miles due to trans install. well i came back from 2 weeks in cali. i finish up trans install and start truck and i here this horrible leak. well i took it all apart today and its crack in the same spot through my weld. so what to do now?????????
her is a pic of the first time
Old Aug 2, 2009 | 06:11 PM
MikeGyver's Avatar
A picture or two of the whole setup would help us re-engineer it for you.
Old Aug 2, 2009 | 06:37 PM
00Silv4.8's Avatar
maybe just a flat piece of steel welded to the pipe and then to like the frame or something?
Old Aug 2, 2009 | 07:16 PM
Coban's Avatar
A crack in the root of the weld will almost always propagate to the cap... You need to grind out the entire cracked weld to repair it. Maybe you did, I'm just saying.
Of course, the actual cause of the crack is important to find too.
If weight was a big factor, wouldn't the north/south sides of the tube be cracking? Instead of the east side.... I would just guess that this is more a heat-expansion/fatigue problem. Supports might not solve that problem.
Old Aug 2, 2009 | 08:56 PM
the slo1's Avatar
is it mild steel? what thickness is it? it looks like it was the pipe that broke the first time, i suspect the heat from the first weld changed the metal next to it. I had a mild steel turbo header on my colt, it broke at a crease on the collector from the shaping process and i fixed it once, then it broke right next to my weld. I took it off after that, I expect the same thing to happen to my mustang until i build some nice thick stainless pipes for it. I agree with the guy above me, grind the weld out, then you could try to reinforce the pipe to flange weld area with some pieces of thicker metal, but i've seen and heard that mild steel is not good for turbo headers
Old Aug 2, 2009 | 10:59 PM
thunderwagen's Avatar
If they are Trick hot parts they should be stainless
Old Aug 3, 2009 | 12:42 AM
zippy's Avatar
Have you shown this to Trick?
Old Aug 3, 2009 | 08:21 AM
TURBHOE's Avatar
no i need to call him. they are stainless. i'm thinking it may have been from my exhaust before i redesigned it. i'm wondering if the exhaust was twisting the turbo. i think mine cracked because i use the wrong wire. i have some stainless wire to weld it up this time. but i need to get ahold of trick. he is just a very busy man.
Old Aug 3, 2009 | 08:43 PM
TURBHOE's Avatar
well we tiged it up. trick was gonna take care of it but i didn't want my truck down any longer. no more exhaust leaks...woot... BUT, i broke an axle. WTF tire wobbled the whole way home. i was only a mile away so i drove it real slow to get it home,
we did however decide that if the crack comes back we are going to weld it up on the truck after driving it. that way it is in its stressed and hot position.
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
