Magnuson Truck MP122HH conversion kit pics............a running work in progress
Old Oct 20, 2006 | 09:12 AM
  #81
moregrip's Avatar
what a rush!
Originally Posted by Richard@WCCH
Go Grippy, Go!!! I for one am really happy to see your making great progress. Remember, before you close the hood don't forget to tighten the bolts on the wheelie bars!!!!
Good luck on the install friend. I'll be waiting and watching and cheering
Richard
Thanks Richard. Your J-Tube looks pretty darn good on the new setup
Old Oct 23, 2006 | 09:13 AM
  #82
BlownChevy's Avatar
blownerator
25 Year Member
Looking good Grip, now get to installin that mountain of parts you have!
Old Oct 23, 2006 | 01:00 PM
  #83
moregrip's Avatar
what a rush!
Thanks brother, I am actually adding to the pile before I start taking away from it and begin installing everything, all the little details are coming together
Old Oct 25, 2006 | 09:46 AM
  #84
moregrip's Avatar
what a rush!
here's some dyno results from a GTO with the 122 (630rwhp):
http://www.ls1gto.com/forums/showthread.php?t=113143
Old Oct 31, 2006 | 12:10 AM
  #85
moregrip's Avatar
what a rush!
small update:
this should compliment the Mototron 60lber's rather nicely
at this point I'm just waiting on a few more parts to finish the conversion, should have those by the end of this week, results to follow.
Old Oct 31, 2006 | 11:48 AM
  #86
04Denali's Avatar
Old Nov 2, 2006 | 02:56 PM
  #87
moregrip's Avatar
what a rush!
more parts showed up today!, all I'm missing now is a front fuel x-over and I'll be good to go
Old Nov 2, 2006 | 03:18 PM
  #88
Bill Reid's Avatar
grippy,
Keep a list of the parts brother... I want to keep the MP122HH as an ace in my back pocket assuming the new TVS stuff is more than a year out or will not be available as a Radix retrofit kit.
Bill
Old Nov 5, 2006 | 01:35 AM
  #89
moregrip's Avatar
what a rush!
a little info I found searching the web tonight, interesting, at least to a geek like me
United States Patent 6884050
A Roots supercharger has an extended cavity with 103 mm diameter rotors having chambers defined by interleaved helical lobes with equal angular face offsets exceeding 60 degrees from inlet to outlet end faces angled in directions opposite to directions of rotor rotation. The chambers have angular seal times of less than 67 degrees of rotation. A preferred embodiment has a displacement of 122 cu inch/revolution, rotor length of 208 mm, face offsets of 65.3 degrees and seal time of 58.6 degrees. The rotor lobe helix angle is essentially 0.314 deg/mm, equal to the helix angle of a prior art supercharger with rotors of common diameter, displacement of 112 cubic inch/revolution, rotor length of 191 mm, previously considered maximum, 60 degree face offset, previously considered optimum, and seal time of 67 degrees. Both flow volumes and efficiency of the new configuration are improved from the prior art wherein the 60 degree face offset was considered optimum.
Old Nov 5, 2006 | 02:22 AM
  #90
A Roots supercharger has an extended cavity with 103 mm diameter rotors having chambers defined by interleaved helical lobes with equal angular face offsets exceeding 60 degrees from inlet to outlet end faces angled in directions opposite to directions of rotor rotation. The chambers have angular seal times of less than 67 degrees of rotation. A preferred embodiment has a displacement of 122 cu mm/revolution, rotor length of 208 mm, face offsets of 65.3 degrees and seal time of 58.6 degrees. The rotor lobe helix angle is essentially 0.314 deg/mm, equal to the helix angle of a prior art supercharger with rotors of common diameter, displacement of 112 cubic inch/revolution, rotor length of 191 mm, previously considered maximum, 60 degree face offset, previously considered optimum, and seal time of 67 degrees. Both flow volumes and efficiency of the new configuration are improved from the prior art wherein the 60 degree face offset was considered optimum.
I'm dummer now!
Jim
