magnavolt questions
i purchased a magnavolt but after looking carefully it shows in the instructions that you are supposed to tie in to the magnacharger intercooler pump well im running a procharger so there is no intercooler pump can someone explain to me how i can make it work or if it will not i would appreciate it thanks in advance
In a Magnacharger kit, you tap into the fuel pump hot wire to power the intercooler pump. It's usually a grey wire that runs from the underhood electrical center to the fuel pump.
You will cut the grey wire from the fuze box to the fuel pump...
Magnavolt Grey wire goes to Grey wire TO fuel pump.
Magnavolt Yellow wire goes to Grey wire TO the fuze box.
Magnavolt Black wire goes to ground... a GOOD one.
Magnavolt Red wire goes to fuze box Positive Battery Post.
Magnavolt White wire tee's to White wire coming from, in your 06's case, Connector 2 Wire 10 of your PCM... I think
... don't worry about intercooler pump wiring you will not use...
Bill
Bill
TAPyvehc93
Sep 12, 2015 08:19 PM
