Magnaflows keep losing packing
Old Nov 24, 2015 | 07:14 PM
sharpshooter's Avatar
Default Magnaflows keep losing packing
I run a magnaflow in front of my corsa and a magnaflow behind it. Over time the magnaflows always burn out all their packing. I've done this to 4 of them. I know it's do to the exhaust temperature and velocity.
Has anyone had a straight through muffler with packing hold up to forced induction?
Old Nov 24, 2015 | 07:28 PM
Vortec350ss's Avatar
My thinking is you are dealing with excessive heat and pressure in your cat back with only a 3" pipe. I'd bet 10PSI at your shift points. The positive pressure is only creating more heat.
Open it up to a 3.5" and my guess is the problem goes away. You will reduce heat and velocity. If you tested backpressure it would surprise you.
Old Nov 24, 2015 | 08:23 PM
Vortec- do you run any additional muffler with your corsa?
Old Nov 24, 2015 | 08:55 PM
03sierraslt's Avatar
Open that exhaust up, I have a thread on exhaust back pressure. Mine was high with a single 3" ( actually 2.8" based on pipe ID) I went to single 4"
Old Nov 25, 2015 | 09:15 AM
I do but mine is a corsa for a diesel, so its a 4" pipe. I have a borla muffler in line.
bluestreak98
Dec 3, 2015 07:46 PM
echoman
Nov 21, 2015 09:33 AM
superbee
Nov 19, 2015 02:22 AM
d-bo71
Nov 3, 2015 01:10 PM
dajuggernoff85
Oct 31, 2015 07:36 PM
