magnacharger questions
I am new to superchargers.. 2001 GMC C3 with magnacharger radix with dynotech headers, built 4L60E with 2500 stall. otherwise stock LQ4.
Currently boost gage is plumbed to rear of charger housing at appears to be upper intake. gage shows vacum but not boost. I have not found diagram to show if should be boost at this location..
Also if I disconnect vacum hose to bypass valve the charger has some knocking/rattling noise... Is this normal??? with vacum connected it sounds fine.
Any info on this combination would be appreciated..
Thanks guys for your replies...
BlownChevy, the 1/8" nipple you are referring to is at rear on driver side, drilled verticle so nipple would point directly upward?
Is the noise in supercharger normal when bypass valve vacum is disconnected? but normal when vacum attached?
