Magnacharger Cam
loose boost? yes the guage reads less but you actually gain power with less pressure leftbehind in the intake manifold.
you have to understand boost is a measure of pressure in the maniflod, not the cylinder.
+36 TQ @ same R's.
331 HP @5250
405 HP @6250.
What is it @ 5250? Dought! My bad. It's showing a peak.
Kinda different RPM peak. I need to check 3rd pic @ 5250 for a more apples - apples comparison. But it's scootin for sure.
I just relooked @ this.
So, I am seeing this right. Yes, it's making power higher up(405). The old peak (331@5250) vs 5250RPMs now appears to be ~381HP. So, @ same level, you added +50. Right?
331 HP @5250
405 HP @6250.
ding ding ding.....we have a winner.
losing boost, but gaining power simply means that the motor is working more efficiently. Add more boost again, and you'll see the motor make even more power.
The biggest advantage I saw with the cam swap was the ability to add more boost efficiently and make more efficient power and being able to stay up in my power band longer.
silverstreak07
Jun 28, 2016 06:29 PM
lawhitediamante
Aug 12, 2015 12:14 PM
