Magnacharger Cam
Old Apr 24, 2008 | 10:13 PM
jephs422's Avatar
Mine before cam
After cam
Your results will vary. This was also with the addition of a Magnaflow catback that gave a dyno'd gain of 7hp.
Old Apr 24, 2008 | 10:15 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
loose boost? yes the guage reads less but you actually gain power with less pressure leftbehind in the intake manifold.
you have to understand boost is a measure of pressure in the maniflod, not the cylinder.
Old Apr 24, 2008 | 10:21 PM
fastnblu's Avatar
Originally Posted by jephs422
Mine before cam
After cam
Whoa, wait a minute. There's 110 hp/tq in PIC1 (Maggie I'll guess). Then I see another huge jump, I forgot how much.
Old Apr 24, 2008 | 10:29 PM
fastnblu's Avatar
+36 TQ @ same R's.
331 HP @5250
405 HP @6250.
What is it @ 5250? Dought! My bad. It's showing a peak.
Kinda different RPM peak. I need to check 3rd pic @ 5250 for a more apples - apples comparison. But it's scootin for sure.
I just relooked @ this.
So, I am seeing this right. Yes, it's making power higher up(405). The old peak (331@5250) vs 5250RPMs now appears to be ~381HP. So, @ same level, you added +50. Right?
Old Apr 24, 2008 | 10:38 PM
jephs422's Avatar
vs. my stock cam, I was able to make more power at a higher rpm also. I had to shift a full 100 rpm earlier before. The gt2_3 did make a huge difference. I was making almost 450rw with that cam.
Old Apr 24, 2008 | 10:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by trever1t
loose boost? yes the guage reads less but you actually gain power with less pressure left behind in the intake manifold.
Finally.......
Its a measurement of restriction.
Old Apr 24, 2008 | 10:59 PM
jephs422's Avatar
Originally Posted by BlownChevy
Finally.......
ding ding ding.....we have a winner.
losing boost, but gaining power simply means that the motor is working more efficiently. Add more boost again, and you'll see the motor make even more power.
The biggest advantage I saw with the cam swap was the ability to add more boost efficiently and make more efficient power and being able to stay up in my power band longer.
silverstreak07
Jun 28, 2016 06:29 PM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
