Maggie intake spacer question?
Old Mar 3, 2012 | 03:26 PM
TurboJohn6's Avatar
Question Maggie intake spacer question?
In regards to using a 1" spacer between the upper/lower intake on an MP112. What are guys doing as far as fuel rail mounting and making up that added 1" of distance between the upper/lower intake? I was looking at going with the EV1 style fuel injector. That would make up 12MM, but what about the approximately 18MM left? Remove some material on the mounting boss on the upper intake? I know they have those 1" long injector adapters, but is that really a good way to go as far as injector efficiency? Any suggestions would be appreciated.
Old Mar 3, 2012 | 03:42 PM
01silvy's Avatar
im intrested in this answer too.. ill be running the spacer on my TVS1900 when i do my build.
Old Mar 3, 2012 | 03:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Subscribed...
Old Mar 3, 2012 | 04:53 PM
TX Tahoe Z71's Avatar
I know one guy used a dremel to cut off the fuel rail mounting tabs and rewelded them to the top of the fuel rail and ran the same injectors. I can get more details on monday, posting from my phone.
Old Mar 3, 2012 | 05:47 PM
TurboJohn6's Avatar
That's a possibility. I would like to see how that looks. I am pretty particular about the way it looks under my hood. Like my **** looking like GM did it themselves!
Actually, one thing I mentioned in my original post that was incorrect. Those injector spacers they make I don't believe are an inch long. They should be 12MM in length. They are made to use in conjunction with the EV14 (48MM) injector so that it will fit in an EV1 (60MM) injector application.
Old Mar 3, 2012 | 06:51 PM
supersub's Avatar
the only 112/122 that uses the 1" spacer is the jackshaft versions, the radix 112/122 use the 13mm or 1/2 spacer.
on the 112 i just recently helped on the injector fuel rail mounting bosses were milled down the amount needed for the proper height, which in turn gave aditional clearance between the fuel rail and rear pulley which was nice.
i will try to upload a photo of what was done.
so far the radix shows nice gains in iat reduction and actual blower temps with the 1/2 alone.
Ray
Old Mar 3, 2012 | 07:49 PM
TurboJohn6's Avatar
Ray
I was hoping you would chime in on this Ray. My 112 is not a jack-shaft version, but I do have a 1" spacer. My spacer is an aluminum one that was made by Trick. It is used to make room for a bigger, more efficient intercooler as well as meth spray bars. So you were able to mill the intake down roughly 1/2" without any issues? It looked like there was enough material there, but I wanted to make sure. I would like to see what it looks like and how exactly you did it. I don't think there is enough material there to make up a whole inch, but with the EV1 injectors and 1/2" of milling, I think it will do the trick. Any other ideas would be welcomed!
Old Mar 3, 2012 | 08:19 PM
jschrock's Avatar
Interesting, sub'd as well. I would like to see some pics of this esp when/if I decide to go meth
Old Mar 3, 2012 | 08:30 PM
Gadgetized's Avatar
I am going to be making my own upper intake real soon, and am just going to cut the tabs off of the original rails to make them work.
Old Mar 3, 2012 | 10:05 PM
montecarloss's Avatar
LS ADDICT/BUILDER
Interested in results also.I have a mp122 on my car and also looking for better IAT's.I want to install a extra heat exchanger and maybe a icebox to see if it helps.I log my IAT at the track,it started at 99 and was 194 when I cross the traps,this was 1/8 pass
