Maggie intake gasket
Old Mar 11, 2010 | 12:53 PM
3DTIM's Avatar
Default Maggie intake gasket
Maggie intake gasket do you have to use theirs or will a felpro work? This is on a 5.3 may have a leak still looking.
Old Mar 11, 2010 | 12:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
For the intake to head gasket, you can use the felpro. It will have some retaining tabs on it that will need trimmed.
Old Mar 11, 2010 | 01:09 PM
3DTIM's Avatar
Thanks this is good to know as not to have to what for one to come all the way from CA.
Old Mar 11, 2010 | 01:40 PM
You already found your new throttle body gasket, right?
Old Mar 11, 2010 | 06:45 PM
3DTIM's Avatar
Yes sir got it yesterday. The new tune should be here tomorrow and see if that clears the code. This one was putting out 11volts to the sensor not 5. I hope that clears the code out. We checked the sensor and it looks to be OK.
Old Mar 11, 2010 | 06:54 PM
TX Tahoe Z71's Avatar
I got a new OEM one from the dealer and trimmed it
Old Mar 12, 2010 | 06:04 PM
3DTIM's Avatar
OK Just what do I have to trim on the gasket? Looks like I will be pulling the Maggie back off. Still getting a code on the Cam Sensor.
Old Mar 12, 2010 | 06:10 PM
Post a pic of your gasket so I can point it out. IIRC, there are retainers that interfere with the Radix, cut them off.
Old Mar 12, 2010 | 06:40 PM
3DTIM's Avatar
Have not got one right now. Going to pic it up first thing in the morning. And a new sensor
Old Mar 12, 2010 | 06:42 PM
Ok, it should make sense to you once you get a look at the gaskets.
