Maggie coolant reservoir location
Im in the process of installing my efans and I need to re-locate the coolant reservoir because it was originally mounted on the fan shroud. I know in the kits from Magnuson they bolt it to the fuse box cover but I was thinking of mounting it to the left of the radiator in front of the battery. It would be tucked up out of the way and mounted directly to the grill support instead of the plastic fuse cover.
My only concern is heat since its so close to the radiator. I plan on putting a heat shield between them made of sheet metal to keep it cool. What do you guys think? I really like this location.
NOTE: In the pics it looks like the hose would hit the ECM cover but when actually mounted it will be up high enough to clear it.
I located my fill spout up high and above the intercooler inlet/outlet so I would be able to fill it completely and evacuate all of the air in the system.(firewall pass. side under fender support) Other than that the location looks good.
I have my tank placed in almost the same place but a bit higher. No heat issue from rad..
Dont mind the Snow Storm we are having on April 2.... Grrrr
If you have the tank filler spout mounted lower than the intercooler you could install an inline hose fill cap up close to your intercooler and this will take care of evacuating all the air in the system and will act as another fill point. However if you remove the tank fill cap you may get drain back from the elevated intercooler and hoses.
I've got the Trick tank mounted on the firewall just under the fender support. It's a perfect fit and I have the pump mounted under the tank so it is gravity fed. Also using water wetter but I'm not sure if it does all that much. Trick tank holds a gallon or more I believe.
1bad2k....LOVE YOUR AVATAR!
Roger (AKlow) & I just spoke about this yesterday before I'd even seen this thread today.
Heat so close to the radiator, or by fuse box, being near headers, which absorbs heat the most IDK. A heat shield between them made of sheet metal or a plastic one perhaps?
Roger, or Mike, so if tank is lower, the side affect of air trapped is bad why? Is it cause of potential hot spots just like rad. /cooling sys. or is it the drain back Mike mentioned below? As in, what's that drainback creating problemwise?
I located my fill spout up high and above the intercooler inlet/outlet so I would be able to fill it completely and evacuate all of the air in the system.(firewall pass. side under fender support) ...
I've got the Trick tank mounted on the firewall just under the fender support. It's a perfect fit and I have the pump mounted under the tank so it is gravity fed. Also using water wetter but I'm not sure if it does all that much. . ...
And yes, 1bad2k has a sweet avatar!!!
