maf or sd
Old Jul 14, 2010 | 06:27 AM
Bromaguire's Avatar
Im running 12lbs of boost on my 6.0. I've got a whipple S/C with a stock 6.0 that I've been running like this for a couple years now.
Old Jul 14, 2010 | 07:00 AM
Chavette's Avatar
Originally Posted by Rick_Vor
When you are ready to get tuned, bring along a Delphi 2 bar - GM# 12615136 to swap out (plug n play) for your stock 1 bar MAP. Just unplug the 1-bar MAP on top of your intake and swap them out. The Tuner has to adjust the tune to recognize the new MAP readings. Then you can keep you MAF and you won't have to add a AIT sensor.
Rick
Using the stock OS or 2 bar OS?
Old Jul 14, 2010 | 09:15 AM
Atomic's Avatar
I have a gauge for that
Rick
At that point the only thing the MAF is doing is being an IAT sensor, it plays no part in the fueling. There are much better IAT sensors out there than the one in the MAF which has a problem with heat soak....
Old Jul 14, 2010 | 03:53 PM
Rick_Vor's Avatar
I'm not a Tuner guy so I'm not sure in what capacity Rick @ Synergy Motorsports used the MAF in my tune. I was pretty sure he said he used a kind of hybrid tune that uses the MAF and SD under boost. It's been a few years so I could be totally off base.
Rick
Old Jul 15, 2010 | 05:54 PM
wentbig's Avatar
All stock 6L @ 11# Boost...with Meth
lucas287
31
Jan 12, 2021 06:18 AM
legerwn
56
Nov 15, 2015 10:21 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
ZxHybrid
Sep 18, 2015 04:44 PM
