MAF or no MAF?
Old Apr 17, 2012 | 09:17 AM
scooter k's Avatar
So I'm going to need to do SD? Will my ECM do SD?
Old Apr 17, 2012 | 11:20 AM
smokeshow's Avatar
Mod with training wheels
There are countless setups running the MAF in front of the TB. It has to be re-calibrated, but its doable... As long as the MAF is after the bend several inches the effects of the intake piping should be minimized.
Old Apr 17, 2012 | 11:24 AM
BlackGMC's Avatar
Resident Retard
If it is after the bend pretty close more than likely you will need to rotate the maf while logging to find the "sweet spot". There have been several threads on tech, efilive and hptuners on this subject. Seems the GTO guys are really affected by this due to all the curves before and after the maf with their setups
Old Apr 17, 2012 | 12:29 PM
scooter k's Avatar
It's going to be really close to the bend. Like a few inches away.
Old Apr 17, 2012 | 12:39 PM
slow67's Avatar
Gingervitis Addict
Originally Posted by MikeGyver
The air bouncing off of the throttle will screw up the readings. So will the turbulence coming out of an elbow when the MAF is too close to the elbow.
That's where GM put it on F bodies
Old Apr 17, 2012 | 07:55 PM
MikeGyver's Avatar
They should have asked me.
Old Apr 17, 2012 | 08:15 PM
scooter k's Avatar
With the LSX-RT manifold and my MAF sensor there is really no room in there to make this work. If I use it the 90* silicone coupler it will be trimmed way back to the bend just about. I don't think it's going to work. Can I set it up for Speed Density with my factory ECM?
Old Apr 21, 2012 | 07:50 PM
robbyredneck's Avatar
yeah why not . i am suprised at how many truck guys still use their maf. if you look at the f-body guys very few use it. set it up for 2 or 3 bar and rock it especially with e 85.
Old Apr 21, 2012 | 07:56 PM
CC05's Avatar
If it's that much of a hassle, why not just SD it? You're going to obviously be forcing a ton of air through the MAF, so I'd just assume scrap it rather than bother with it.
Old Apr 21, 2012 | 08:06 PM
scooter k's Avatar
Got my self a 3 bar MAP and IAT!
