MAF or no MAF?
There are countless setups running the MAF in front of the TB. It has to be re-calibrated, but its doable... As long as the MAF is after the bend several inches the effects of the intake piping should be minimized.
If it is after the bend pretty close more than likely you will need to rotate the maf while logging to find the "sweet spot". There have been several threads on tech, efilive and hptuners on this subject. Seems the GTO guys are really affected by this due to all the curves before and after the maf with their setups
With the LSX-RT manifold and my MAF sensor there is really no room in there to make this work. If I use it the 90* silicone coupler it will be trimmed way back to the bend just about. I don't think it's going to work. Can I set it up for Speed Density with my factory ECM?
