Maf is driving me crazy! Help!
Old Feb 6, 2011 | 08:30 PM
casper02's Avatar
Default Maf is driving me crazy! Help!
So two codes are getting thrown p0101 & p0102 any ideas guys it drives me crazy cus itll throw the codes and my truck will turn of on me ive gad tgis done twice on me. O btw mods are 347 iron block,cam and procharger
Old Feb 6, 2011 | 08:48 PM
Daryn's Avatar
Formerly darynC-10/23/10
do u have a bov on the procharger? is the maf before or after the bov?
Old Feb 6, 2011 | 08:59 PM
casper02's Avatar
I have the original bypass valve it came withand its after it.
Old Feb 6, 2011 | 09:14 PM
Daryn's Avatar
i have heard that if you put the vent after the MAF ,, it will act crazy, i have put mine befor ethe MAF and it runs fine, im turbo though
Old Feb 6, 2011 | 09:19 PM
casper02's Avatar
Damn I cant figure it out make me wanna pour deisel on it and light a match and walk away lol
Old Feb 6, 2011 | 11:14 PM
Rick_Vor's Avatar
CausesA code P0102 may mean that one or more of the following has happened:
The MAF may be disconnected, or a wiring connection may be bad
The MAF may be dirty or otherwise contaminated (Note: if you use a reusable oiled air filter, be careful not to apply too much oil or that can contaminate the MAF).
The MAF sensor may be faulty
The vehicle computer may be faulty (very rare)
Possible SolutionsThe simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
Inspect for any air leaks near the MAF sensor.
Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
Replace the MAF sensor.
Do you have any oil in your cold pipes? It could be a bad seal or just too much oil on your K&N style air filter. I'd grab some TB spray clearner and give the MAF a good cleaning. If that doesn't work, try swapping it out with another MAF from a good running truck.
Rick
Old Feb 6, 2011 | 11:24 PM
casper02's Avatar
No oil watsoever already did the maf swap I had extended the maf wires along time ago could that b it?
Old Feb 8, 2011 | 09:40 AM
FarmTruc's Avatar
Performance Trucks Sponsor
That's exactly it , it's an open wire in between the maf terminals and pcm terminals. May or may not be your splicing, but GM wiring is known to have open and corroded terminals on that connector and the throttle body.
Best solution and quickest, is to replace the three wires with new ones.
It'll fix it.
Old Feb 8, 2011 | 01:05 PM
casper02's Avatar
Will do allen
GXPJAY
Feb 13, 2022 08:15 AM
slowmo934
Sep 9, 2015 12:24 PM
Fast86z
Aug 23, 2015 12:35 AM
02singleturbo
19
Aug 20, 2015 05:55 PM
