LSX376 B15 W/TWINS 2002 silverado 4X4
Old Jan 25, 2020 | 10:57 AM
stacy moore's Avatar
Originally Posted by smokinlmm
Go for it! You going to compound or sequential it?
smokinlmm -I don't know the differences! could you explain the differences in layman's terms ?
Old Jan 25, 2020 | 11:08 AM
03sierraslt's Avatar
Originally Posted by ZO6Ted
Is the rotating assb inferior? Guess GM studs too?
They use stock bolts. Of course GM performance would say that, I would at least change the cam.
Old Jan 25, 2020 | 01:09 PM
smokinlmm's Avatar
Compounds one larger turbo feeds a smaller turbo compressed air which then gets compressed again. Sequential turbos smaller turbo spools up first then gates exhaust pressure to a larger turbo which takes over boost without assiatence from smaller turbo. True twins are seperate spooling turbos indepently feeding intake tract.
Old Jan 25, 2020 | 01:17 PM
Twin 7875’s would be over kill for a 376ci, look for something smaller. What’s your hp goal? That’s how you size turbos, not based on boost.
Old Jan 26, 2020 | 12:27 PM
smokinlmm's Avatar
^^^ Yep, need to match your cfm up to your goals, boost dosent mean ****, it's just a measure of the restriction of air...
Old Jan 26, 2020 | 06:49 PM
Ok you guys are correct on the boost so Lets say power goals of
1000 HP
1250 HP
1500 HP
1750 HP
Old Jan 26, 2020 | 07:03 PM
from hot rod mag. It can hit over 1000 HP with a precision PT7675 featured a 76mm compressor wheel, GT42-style compressor housing with a V-band discharge flange, and a 75mm (84 trim) turbine wheel and Equipped with the Brian Tooley Racing Stage 3 turbo cam and Holley Hi Ram intake,
The final 1,082hp (top) run continued the trend, starting at 23.2 psi before dropping down to 18.8 psi.
Data logging showed the backpressure to exceed boost pressure by more than 10 psi (and climbing) at the power peak
so
@ 836 HP / 10.5 # = 79.61 per # of boost
@ 951 HP / 14.6 # = 65.13 per # of boost
@1083 HP / 19.5 # =55.53 per # of boost
so 30# of boost x 55.53 HP per bound of boost should net 1665.9 HP or a little better because of twins lowering the high back pressure ? IDK.
Old Jan 26, 2020 | 07:06 PM
arthursc2's Avatar
This thread is full of win
everything from magazine racing to throwing around useless qualifications about build quality and value
good luck man! You claim to know enough to know you want 2000hp, but yet you can't read a compressor map?
Hmm
Old Jan 26, 2020 | 07:15 PM
that’s one, your talking about two. Not sure what your point is. So your power goal is 1000-1750hp?
Old Jan 26, 2020 | 07:30 PM
Cool
Hmm
YOU ARE CORRECT Sr. that is why im here asking questions .... ive tried to read the maps but cant understand them.
