Lsa swap what intercooler pump did you use
Old Nov 18, 2016 | 06:00 PM
  #21
GM1697's Avatar
Originally Posted by musclecity85
these were the other 2. im not sure if these are right either. how would you recommend routing the hoses?
The second one, "norcal box" being your tank. Just make sure the line coming from top of blower goes into the upper fitting on your tank, and then lower port on the tank would feed the pump.
Old Nov 18, 2016 | 06:20 PM
  #22
musclecity85's Avatar
thanks..ill check that out and re route my lines tomorrow
Old Nov 18, 2016 | 06:26 PM
  #23
GM1697's Avatar
No problem, take pics if you are confused.
Proper routing will absolutely help your IAT's
Old Nov 19, 2016 | 04:32 PM
  #24
Lt1z383's Avatar
Spent some of today mounting exchanger
Old Nov 19, 2016 | 05:03 PM
  #25
GM1697's Avatar
Looks good, but I doubt that HEX cap will be the highest point in the system.
Old Nov 19, 2016 | 06:21 PM
  #26
Lt1z383's Avatar
Your right not gong to use it. Going to get a tank like u recommended and mount in spare battery space. Pump should be lower then hx correct? Mounting that and hoses tomorrow.
Old Nov 19, 2016 | 06:42 PM
  #27
Vortec350ss's Avatar
Pump does not need to be lower than the HEX, just lower than the tank that feeds it.
Old Nov 19, 2016 | 07:46 PM
  #28
turboal1's Avatar
Default Water flow
For street use the 1st of you 2 pics is the right way
Old Nov 19, 2016 | 07:49 PM
  #29
GM1697's Avatar
The two he posted are actually identical.
Old Nov 20, 2016 | 11:54 AM
  #30
Lt1z383's Avatar
So the second set of pictures are correct? The box being the tank we use.
