Lsa swap issues
Old Oct 19, 2016 | 03:47 PM
  #31
embs2001's Avatar
Did you ever figure out what was causing the lean stumble?
Old Oct 19, 2016 | 03:52 PM
  #32
musclecity85's Avatar
No I didn't. Since It mostly went away when the truck was warm I just live with it. I think it's in the tune. I'll bbe getting a retune once I do a cam swap
Old Nov 17, 2016 | 11:33 AM
  #33
Lt1z383's Avatar
If had hp tuners or access to it sure I can fix it. Sounds like pe might be delayed especially if already on lean side of 15.0
Old Nov 17, 2016 | 11:47 AM
  #34
Ive been thinking about buying hp tuners. And if I could figure it out that would be great
Old Nov 17, 2016 | 12:18 PM
  #35
GM1697's Avatar
HPT is a worthwhile investment.
Old Nov 17, 2016 | 12:35 PM
  #36
I know I'm just being cheap. lol It would probably pay for itself just for the data logging capabilities.
Old Nov 17, 2016 | 01:43 PM
  #37
embs2001's Avatar
Hey, what size throttle body are you using?
I switched from back from my ebay 90mm to the stock 78 truck and the stumble went away. It still spikes lean when I crack the throttle but I guess it helped it enough to get rid of the annoying stumble.
Old Nov 17, 2016 | 01:49 PM
  #38
I'm using my stock 87mm TB.
Old Nov 20, 2016 | 08:01 AM
  #39
Lt1z383's Avatar
Yea the logging alone is worth it when your running a setup that can easily take out a piston. Sometimes your getting detonation and don't hear it. A lot of tuners think becaus it runs it is right and not even close to optimized where being able to log comes in for sure. If u end up with it I can help you on the tune. So many things need to change from a major setup to blown for fueling it can easily get a lean stumble and if not working with logs you will pull your hair out trying to fix it. A lazy tuner will always blame what they cannot fix on a mechanical issue. The easy way out really.
Old Nov 20, 2016 | 08:07 AM
  #40
I can agree with that. I had a big name shop in mooresville NC tune mine. And I'll just say I was not happy with it. So hopefully someplace will have a sale for the holidays and I'll grab it. Is the hp tuners pro version absolutely needed?
