LS9 (ZR1) Cam in a FI GEN III?
Old May 14, 2010 | 12:41 PM
Atomic's Avatar
I have a gauge for that
I was thinking the gt7 would be cheaper in the long run because its already a gen3 cam and very similiar like you said...
Old May 14, 2010 | 02:09 PM
1Bear's Avatar
Originally Posted by Atomic
why not use the lpe gt7?
I understand your reasoning and I'm with you as far as not wanting to have to convert to a Gen IV set up to allow use of a Gen IV style cam, but unless you find a used GT-7 you would be out of luck. Lingenfelter say's they have discontinued production of the GT-7 since there are so many similarities between the two and of course the price savings of the camshaft alone.
Old May 14, 2010 | 03:01 PM
EVILGMC's Avatar
custom cams can be had for under $300. YOU CALL IT. they are not a sponsor here, but PM me for info.
Old May 14, 2010 | 05:51 PM
zeake's Avatar
http://www.proheads.com/ can get you a custom cam straight to you from comp cams. I can't remember how much mine was but it was very competitive.
Old May 14, 2010 | 06:46 PM
charcold-bowtie's Avatar
yall are missing some of the point that although the ls9 may be cheaper, its a gen 4 cam, so it will end up costing about the same.
Old May 15, 2010 | 12:55 PM
lq4powereds13's Avatar
Going with this cam in my 5.3l gen 3, found a lightly used 05 ls2 timing cover, cam sensor and cam sprocket for under a hundred and will extend my cam sensor harness myself. Just gotta look for deals.
Old May 15, 2010 | 02:23 PM
It would be cheaper for me to stay with a GEN III cam.
Bottom line is that I want more power at or around the same boost level that I'm currently at. I dynoed 420 RWHP 510 RWTQ at 7 PSI (WG spring only). I would like 500 RWHP, so if a cam made for boost would get me there over my current LS6 cam then that's the direction I'll go. Obviously I could put a boost controller on or different WG spring and get more boost, but I'd like to keep it on the low side to keep my motor alive longer. Your thoughts?
Old May 22, 2010 | 05:33 PM
sparkwirez06's Avatar
I was going to use that cam, the specs, don't remember exactly, were simillar to the ls6 except for the lift. I just put yella terra 1.8s on and have .582 204/218 lsa117, with my ls6cam!! There were a lot of them on ebay selling under 100 bucks!!
Old May 22, 2010 | 06:04 PM
LS9Cam specs, 211/230//558/120lsa.
Old Jun 7, 2010 | 11:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
Thank you Lingenfelter!
