LS9 Cam for Turbo 5.3L
Going to be boosting my 5.3L soon, looking for 500+rwhp. I bought a new LS9 cam from a member on a whim. Right now the truck has an '00 LS1 cam which I put in while the engine was apart. I will be taking off the timing cover to install an oil drain, and could swap the LS9 cam at the same time since it's not too much extra work. Here are the cam specs:
LM7 5.3L: 190/191 0.466/0.457 114 LSA
00' LS1: 202/210 0.496 /0.496 116 LSA
LS9: 211/230 0.558/0.552 122.5 LSA
Right now I'm leaning towards not swapping it in. From what I've read, turbos seem to like even or reverse split cams. LS9 cam seems better for a blower or something, although the reviews and opinions on it are very mixed, not many people have tried it yet. I do not want to buy a new cam unless it's a used LS6 cam or something for cheap. Whatever cam I go with needs to pass CA smog. The turbo will come off but the cam will stay in.
Thanks!
Thanks!
FYI, the C6 Z06 cam is almost identical to the ZR1 cam, minus the fact that valve lift figures as based on 1.7 rockers on ZR1 and 1.8 rockers on the Z06 if i recall.
Just because the cam is labeled "ZR1" and you owned one, doesn't make it the cam of kings--it has its downsides. The cam should match up with the air volume forced in by that turbo. The ZR1 is blown and has the cam, I know. Z06/ZR1 cam does have its differences, and the rockers affect lift. Stock48 builds engines for a living. You pay people to put lowering shackles on your truck. No need to be a smartass.
Sharty_McQueef (08-04-2022)
Plus where did I say the ZR1 cam is the king of cams? but out of those three it would make the most power.
