LS6 Head Gasket Question
Old Apr 25, 2012 | 03:52 PM
Half-bred's Avatar
Default LS6 Head Gasket Question
I was wondering how much boost has people but to the LS6 gaskets with head studs. On a 6.0L on the street? Thanks
Old Apr 25, 2012 | 03:59 PM
02'Z71ONDUBZ''s Avatar
I don't think very many people run LS6 gaskets at all. I wouldn't expect it to be much better than standard GM MLS gaskets. With studs you could probably boost it to 16-17psi without trouble. LS9's are a much better option for boost.
Old Apr 25, 2012 | 04:02 PM
Half-bred's Avatar
No I'm sorry they are LS9 gaskets my Bad..
Old Apr 25, 2012 | 04:07 PM
Something else is gonna break before you lift a head with that setup.
Old Apr 25, 2012 | 04:14 PM
Half-bred's Avatar
I hope not if anything it will be the rearend, I have a built T400 behind it and the motor was just rebuilt, But do any of you guys have alot of piston slap?
Old Apr 25, 2012 | 04:49 PM
TXSZ66AVLANCHE's Avatar
Nothing special about the ls9 gasket....its same as the ls3 gasket.
Old Apr 25, 2012 | 04:52 PM
kbracing96's Avatar
I believe the LS3 gasket is 5 layer and the LS9 is 7 layer .
Old Apr 25, 2012 | 05:12 PM
both are .051but different bore size 4.100 vs 4.080
Old Apr 25, 2012 | 05:15 PM
The relevant difference is in the extra layers of the gasket. GM probably engineered it with boost in mind
Old Apr 30, 2012 | 08:38 PM
Y2KLimited's Avatar
well in regards to the LS6 gaskets......21 pounds on my LS6 with studs and unported LS6 heads as well and didn't lift the heads. Pump gas and meth.
