LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!!
Old 07-28-2011, 01:26 PM
  #101
jeffreycastgsx's Avatar
Originally Posted by Spoolin
If you guys want I can try to find out what the fuel pressure was. No guarantee's but I'll give it a shot.
We're also so used to comparing numbers in vehicle and not on a engine dyno that there's probably a few more variables that were forgetting that is affecting the numbers. Either way it's cool and I just find it hard to believe HR lied without seeing a smoking gun in hand.
Find out, because all evidence proves they didnt make the HP advertised. Just ask the them, or redirect them here.
Old 07-28-2011, 01:32 PM
  #102
TX Tahoe Z71's Avatar
And who said they had to run their injectors at 80% IDC? We have a handful of members rocking IDC's of 115-120% on FI. Not advisable but the engine doesn't spontaneously combust either.
Old 07-28-2011, 01:39 PM
  #103
You do know what 115-120% idc means right? 100% duty cycle is the injector open the whole time 100%, can you guess what 115-120% is? Nothing more than 100%. YOU CANT GO ABOVE 100%, its always just a guess based on whats "needed or wanted". Im sorry i dont post much, but this stood out to me, there packing 10lbs of potatoes and saying they got 20lbs. Maybe a typo, but they mentioned the 75lb injectors more than once, im the last person to read magazines because of this and the biased opinions/facts ALWAYS found in all magazines.
Old 07-28-2011, 01:58 PM
  #104
Yes, I understand IDC; it's a calculation of injector pulse width vs engine RPM (actually pulse width in ms over cycle time in ms, not a guess, as you call it). My point was that just because the injector is open for the entire cycle (100%) at a certain RPM doesn't mean they can't spin the engine faster and create more HP (thus greater than 100% IDC).
Old 07-28-2011, 04:36 PM
  #105
Ieatpeople's Avatar
i would bet, that since its an engine dyno, their fuel pressure is probably whatever they feel like setting it to. maybe 120psi+
if your trying to tune an engine for use in a vehicle, they would set the fuel pressure to the pressure you could reasonably run through the fuel pump you're going to use. for all out power on the dyno, they just crank it up to whatever they need to get the most out of the injectors.
Old 07-28-2011, 04:53 PM
  #106
Mod with training wheels
smokeshow's Avatar
That is true of the older fuel systems. Newer ones are bit different though. They leave the injector on outside its normal window of operation to prevent a lean condition. Mine doesn't begin to swing lean until like 125% IDC.
Old 07-28-2011, 05:05 PM
  #107
Rarely does it REALLY go above 100%, in terms of TRUE fuel flowing, after 100% its more of a "guess". The computer is really just commanding that much flow from the injectors but it cant supply, so after its just guessing how much it wants, but cant keep up. 120% duty cycle flows the same as 100% duty cycle.
Old 07-28-2011, 05:51 PM
  #108
Old 07-28-2011, 06:03 PM
  #109
I have a gauge for that
Atomic's Avatar
Someone from the magazine should pop in here soon...
  #110
Ieatpeople's Avatar
can't you open the injector before the intake valve opens? thereby creating more than 100% duty cycle?
correct me if i'm wrong, but i assume the idc is at 100% when it opens and closes at the same time as the intake valve. if you open it before the valve opens, you can get extra fuel into the cylinder, making the idc more than 100%
unless you're referring to the 100% idc meaning the injector hangs open continuously...
Quick Reply: LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!!
