lq4 + tvs2300, LS6 cam or ls9 cam?
Old Oct 29, 2015 | 07:28 PM
camarokid6771's Avatar
Default lq4 + tvs2300, LS6 cam or ls9 cam?
66k mile long block, I was planning of opening up the ring gaps, ls9 head gaskets, head studs and having a keyway cut in the crank.
I have both cams here to pick from which is the better choice?
I also have yellow ls6 springs and comp 921 doubles here to pick from
raceweight will be 3000-3200lbs. headers are 1-7/8
NOTE: this is a temporary motor to play and learn with. I already have another LQ4 here to build up properly with good sh|t.
ive also thought about doing nothing to it and letting it eat LOL
Old Oct 29, 2015 | 08:06 PM
ZO6Ted's Avatar
IMO no contest...LS9. Had the LS6 and loved it but you need more.
Old Oct 29, 2015 | 11:25 PM
Vortec350ss's Avatar
Grab some LS3 heads while you're at it and crank up the boost.
Old Oct 30, 2015 | 12:21 AM
10 Second Truck Club
Ls9 imo
Old Oct 30, 2015 | 09:49 AM
zero2sixT's Avatar
do this
Old Oct 30, 2015 | 10:29 AM
LowSilver's Avatar
I'd go LS9 out of the two choices. Also, why not just do ARP head bolts over studs and save some $$$ there?
-Kenny
Old Oct 31, 2015 | 08:44 PM
old motorhead's Avatar
Of the two, LS9 for sure. If you're going to swap the cam anyway, I wouldn't use either. If someone gave me either one, I'd sell if for what I could get and go custom. On a 6.0L, there's no down side to a low to mid 220's intake, low to mid 230's exhaust, and a 115 to 118lsa with appropriate advance. Perfect manners and more power are there for the taking.
A custom cam is pretty cheap in the grand scheme of things. Lots of value for the buck right there.
3 to 3.2K race weight? Sounds like a fun project. Big boost just off idle in a light *** ride is all kinds of fun!
Old Oct 31, 2015 | 09:03 PM
03sierraslt's Avatar
Q
I agree with all of this. No doubt. Thus my reasoning for my cam specs. 224/236 115
Old Oct 31, 2015 | 10:20 PM
I'll echo Pat and Motorhead on this one. There is so much to be had from a different cam.
Old Nov 1, 2015 | 07:02 PM
terravast4's Avatar
i agree...i even feel my gt2-3 is on the small side. wish i went bigger
