low mount ?'s
Old Dec 9, 2012 | 08:09 PM
turbo-ls7's Avatar
Registered User
The money you spend on a low mount you can have a front mount from kb or trick eather one is bad azz
Old Dec 10, 2012 | 09:16 AM
05GMC4.8's Avatar
Not so true. Im in the process of piecing together a low mount turbo and when its all said and done meaning fueling and tuning included ill have less than 2k into the entire setup. Being patient goes along way. Will it make as much max power as a kb/trick kit? Probably not but this setup for me isnt about max power. The front mount look cool as **** tho and some day i will go front mount but with twins :-)
Old Dec 10, 2012 | 12:13 PM
FarmTruc's Avatar
Performance Trucks Sponsor
There's a difference between a low mount and rear mount, even mid mount.
Here's a low mount, which will make the same power as a front/top mount.
It's not located in the rear obviously.
Rear mounts do compromise on a few things, but still make decent power and are easy to make.
should be starting up this week.
Twin 70's behind the 408 in an OBS truck.
Old Dec 10, 2012 | 02:59 PM
Alpinestar's Avatar
Are you buying everything used? 2k sounds like a stretch. Don't forget about your transmission.
Old Dec 10, 2012 | 05:02 PM
05GMC4.8's Avatar
Well since it was brought up mine is technically gona be a mid mount. Some parts used some new and all work done myself except the tune. And im well aware of the failure prone 60e but thats another project.
Old Dec 10, 2012 | 06:36 PM
turbo-ls7's Avatar
Registered User
Well u need a built 60e I have one from century transmission let it go for 1300 no stall built for 800hp and that's shipped too so let me know less than 2000 miles so its fresh
Old Dec 10, 2012 | 07:55 PM
BUTTERB30's Avatar
SO far ive honestly spent prob about $1500 for my low mount stuff and im just missing another hundred bucks worth of 10 an oil hose and fittings and then whaaaalaaaaa
Old Dec 10, 2012 | 10:17 PM
turbo-ls7's Avatar
Registered User
Good luck whith that 10 dollar hoes try 50 bucks g
Old Dec 11, 2012 | 04:56 AM
BUTTERB30's Avatar
AND PRETTY MUCH every part i have gotten is from TRICK PERFORMANCE including oil lines just not the turbo
Old Dec 11, 2012 | 02:44 PM
He said 10 an hose, meaning -10 an hose for the drain
