Losing coolant in H/E for Radix
I've had the Radix on for a few years now and i've noticed that i have to add about a cup of dex-cool to the resevoir every few months. Is this normal?
I also clean the resevoir every time I add coolant and it's pretty dirty. I have a feeling that fluid is very slowly leaking out of the resevoir and dirt is sticking to the residue on the container.
I've had mine on for almost a year now, mine is still nice and tight. Level is still dead on where I initially filled it. I would be curious though of what others have to say.
You could pressurized the system, and maybe find a leak. If the pressure bleeds off, then it is leaking somewhere. If you can see a leak it could be the intercooler, or the fittings that run through the upper intake manifold. It should not lose any fluid over a period of time.
