looks like i need dual pumps now
J, if I read your posts correctly you currently have no fuel problems, right? At up to 12 PSI you are at 11-11.2 A/F and the fuel pressure is not dropping. So you are just wanting to upgrade just in case or to add more boost.
With how well one Walbro 255 is working why not go with the dual Walbro setup like the ones Nasty/Lonnie sells? I like how it only kicks the second pump on after a certain boost level that way it doesn't heat up the fuel too much by flowing too much and having to return it to the tank.
No problems yet, the single pump is about 4 years old and i dont want to tempt fate
12psi and with the AFR at 11.1 the pressure looks to be holding on my autometer gauge. but i havnt really watched it too close on nitrous, but the AFR stays at 11.0.
I thought about twin pumps for a long time.. but this single 044 was cheaper and should be plenty for what i want to do..
Oh and them injectors might be on their limit on 16# boost..
To max them out or not...
-Nate
thanks, Rick
I found this on a Vendor Site. It looks like the Bosch 040/044 rates pretty well at 60 psi vs the Walbro HP255 adn the Aeromotive.
I'm already running a Walbro HP255 in my tank. I wonder if there is any advantage to using the Walbro to feed the 044 and run them both all the time? Since I have a 2005 returnless system, I would have to add a FPR after the 044 and pump it back to the tank. Could even try to use a 1" diameter x 12" pipe in between the tank and the rear mounted inline 044. That might keep the 044 from sucking the 255 dry.
Rick
Rick
