Looking for pics of catch can install
I'm getting ready to do a catch can breather tank on my truck and I was seeing how everyone else had there's set up if u guys can post up pics that would be sweet
Here is one example, but if I were you I would cap off both side ports on the passenger valve cover, along with the ports on the throttle body, and get an oil fill cap that is a breather cap. Then, pick up a ford pcv valve out of a supercharged v6 thunderbird, its a direct replacement and has a built in check valve to prevent you from boosting your crankcase. Route from the pcv to the catch can, then to the intake. This will allow the engine to draw fresh air through the breather as needed, keeping the pcv system working as designed without the negative issues boost or the oem pcv system can create.
However, I just vent mine
therock
Jul 25, 2015 09:23 AM
