Limits of a returnless system.
Old Feb 10, 2012 | 09:10 AM
bk_cauley's Avatar
okay here is kinda what i had in mind. Do you guys think it would support 700 hp. as long as i have sufficient pump and injectors.
Old Feb 10, 2012 | 10:07 AM
kbracing96's Avatar
If that's how your gonna build it with the reg out side the tank, I would not use the Corvette filter/reg, I'd just uses a regular return style reg AND boost reference it. You'll basically have a return system with a returnless fuel rail which will support quite a bit of power I believe.
Old Feb 10, 2012 | 10:11 AM
bk_cauley's Avatar
Yea im scrapping the vette regulator idea. and The regulator im looking at is boost referenced so thats a plus. So far its looking good.
Old Feb 10, 2012 | 12:11 PM
Atomic's Avatar
I have a gauge for that
Your diagram is a returnless setup, except from the regulator back is in the tank. If you are intent on running this setup, I would use bigger line from the regulator to the rails. The big advantage of a return setup is not all the fuel has to flow through the regulator - only the fuel thats not used, which at WOT, isnt much.
Old Feb 10, 2012 | 12:14 PM
Mangled03gmc's Avatar
Baltimore Whore
The stock lines and rails will support 1000 hp or so. Now the pump/injectors is a different story
Old Feb 10, 2012 | 12:33 PM
bk_cauley's Avatar
Originally Posted by Atomic
. If you are intent on running this setup, I would use bigger line from the regulator to the rails..
the regulators im looking at only have -6 input/outputs. Do you think it would still be benificial to use adapter fittings to go up to a -8 line even though the regulators only -6.
Old Feb 10, 2012 | 12:36 PM
Atomic's Avatar
yes because of the higher volume of fuel in the lines, but to be honest, I think it would be a waste. Just upgrade the pump until you are ready to convert to a return system.
Old Feb 10, 2012 | 12:43 PM
bk_cauley's Avatar
You are aware that this is going into a f150 right? im doing a 5.3 swap in it.
Old Feb 10, 2012 | 01:22 PM
Atomic's Avatar
Yes. The fuel system parts dont care if they are in a leaf blower or a ZR1, much less an f150 vs a silverado. All pumps, regulators, injectors, rails, etc., work exactly the same.
Old Feb 10, 2012 | 01:30 PM
bk_cauley's Avatar
The stock lines on the f150 are tiny. Im deff not using them. and ive already got the tank sumped and ready to run a.n fittings and line.
