Light cruise A/F
Old Nov 12, 2009 | 02:31 PM
arv8100's Avatar
Default Light cruise A/F
You guys running MAF's and dedicated Wide Bands what A/F does the ECM keep you at while in light cruise and idle?
Old Nov 12, 2009 | 02:57 PM
kbracing96's Avatar
Should be in closed loop with the PCM targeting 14.7.
Old Nov 12, 2009 | 06:09 PM
terravast4's Avatar
Old Nov 12, 2009 | 06:16 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by terravast4
14.7 - 15.2
Ditto.
Old Nov 12, 2009 | 07:32 PM
Mangled03gmc's Avatar
Baltimore Whore
Yep ^^^^^^^^^^^^^^^ All though I am going to get the lean cruise done soooon..
Old Nov 12, 2009 | 10:26 PM
viciousknid's Avatar
Where's the Beef?
I run mine 15.5 it's sometimes 15.2-15.7 but most of the time it's spot on. No SD should command 14.7 or 14.8 as mentioned.
COS3 SD FTW
Old Nov 12, 2009 | 10:35 PM
dirt track racer 81's Avatar
im 15.8
Old Nov 14, 2009 | 04:41 PM
TURBHOE's Avatar
how does it run at that ratio? hows throttle response? i tried that and mine was alittle ruff.
Old Nov 14, 2009 | 06:16 PM
its only 15.8 right at cruise rpm and kpa anything over it richens up. works just fine for me.
Old Nov 14, 2009 | 06:28 PM
terravast4's Avatar
sometimes it dips in the 15's at idle and it does get a little rough
