Let's talk BOV's
What's everyone's opinions on which BOV to go with, there's so many out there in really sure if I can go wrong with picking one or the other. Tail, Turbosmart, JGS, on3. Anybody have any insight on these?
Thanks - Kyle
Thanks - Kyle
Twin Tial 50s
Id like to run precision ones but money wasnt there
Dunno why im not fan of jgs products
Ive used on3 50mm in pair on TT-Notch but owner didnt want to spend the money
In end make sure you have enough bov for power level...a 50mm was designed for a 2.5 tube and works great for low boost...once you get over 20 with a serious setup youll find it out as it may not vent eough so twin 50s or larger singles are required
Local car makinf 1300 had a single 50 on 4" pipe and bemt his throttle blade..swapped to dual 50 problem solved as twin 50s is 100mm and 4" is 101.6mm so it will vent all pressure
I wouldn't run anything but tial.... Just cause they're the best, in my opinion, and not to mention they're made in the USA! Not sure about any of the other companies, but countless people use them. Another brand most people are not aware off is boosted solution... Their BOV look pretty legit!
In my opinion a wastegate is more important as if they fail, you overboost. If a BOV fails it stresses the turbo or throttle blade. I run a 46mm Precision gate, and a Tial 50mm BOV.
Whenever you mount a BOV mount it as close to the throttle blade as possible to reduce the stress on it.
I always here praise and great results with the tial bov's but has anyone used a procharger open race bov on these turbo setup's? I have a new open race valve with aluminum flange out in the garage and had thought about using it on my truck instead of the ebay "tial" knock-off that i have now.
