Let's see if a TVS 1900 can handle a 408!
Old May 29, 2008 | 07:38 PM
  #21
leftcoast32's Avatar
FormerVendor
[QUOTE=zippy;3930065]Is the L92 system using the same intercooler as the older MP112's? I remember seeing somewhere that they are available now, but I haven't gotten to play with one yet and really want to see what they can do. I was hoping that the new lower intake would have an intercooler similar to that of the LS9 which has an impressive intercooler system.
The Inlet Forward design is alot different then the Radix. The Intercooler we am using with the Inlet Forward MP122HH's is the biggest one we could fit in it. I was tuning Grip's Radix MP122HH at 10psi of boost and his runs real cool also. Remember that both of us are running dual heat exchangers installed in series.
I know the MP112's and MP122HH's I've worked with have had IAT issue's. I do understand that the front inlet, 90mm throttle body, and larger maf really help reduce restriction which gains you boost without the blower having to work so hard to get you there, but those kind of IAT's are just amazing for how fast yours must be spinning. Very cool.
The 90mm Throttle Body and 100mm MAF really help to reduce the vacuum in front inlet during WOT. I think it is more a combination of the Dual Heat Exchangers, Heads, Cam, Exhaust and less inlet restriction that help to reduce the temps.
Old May 30, 2008 | 01:15 AM
  #22
Spoolin's Avatar
GFYS and STFU
Ya the CR plays a big role in that.
See...I knew I was missing something!! yeah I'm 9.2:1 That helps too!
Originally Posted by 04Denali
Jullien
YOU SUCK
Don't hate...imitate!! Oh snap you can't!! HAHAHA hate all you want biatch!! Muah!
its OK, my 14 psi against your 18psi and my 900lbs more, we shall see
Normally I'd say yes but you also have AWD so I'll pass!!
Well see once I get the bugs worked out!
Originally Posted by 8ALTNG
And my 10psi against your 14psi
I am interested to see the results of this setup.
Your a cheater because you weigh so little and never post vids!!
Hmmm...sorry for the offtopic!
I just wanna see what the 1900 does with the 408.
moregrip
Jul 26, 2016 11:21 AM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
BCraven1018
Oct 1, 2015 08:22 PM
JoshH
Sep 28, 2015 11:19 AM
