Lets play guess my HP & TQ
6.0 lq4
.020 over
flat top pistons
BTR stage 2 turbo cam
front mount on3 70mm turbo- 8psi
stock 317 heads
fast 92/92 with fast 60lb injcetors
4l80e with 2800 stall
4x4 truck with a 14 bolt rear axle, 373 gears, and 33/12.5 on a 20x12 wheel
just waiting on intercooler and hot side and the swap will start. What do you guys think itll make?
.020 over
flat top pistons
stock 317 heads
Are you wondering crank hp or rwhp? Cause i think youll only bee able to do pulls in 2nd gear which is going to rob even more horsepower
Isnt that turbo on the smaller side for 6.0?
My truck's similar by it being 4x4 and big tires and look what I made, granted thats at only 7 psi
and yes it is, I just got a good deal on it and am not aiming to make crazy numbers
its a 95 gmc z71 ex cab short bed with a 6 inch lift and 35s for now. I have plans for a solid axle swap once I get the new motor running and tuned after i do the SAS im going to have around 4.5 inches of lift and 33's
