Let the fun begin
Old Jan 7, 2011 | 09:17 AM
3DTIM's Avatar
Originally Posted by pkozera
I love the low end feels strong puts you back in the seat but the poorl60 wont last to long. Also having a rolling idle prob put the scan tool on it and went to functional test and can control the iac up and down and it responds perfect have checked for vac leaks nada. Did not have idle prob until i cut the iat out of the mass anyone ever seen this and what to do to fix think it might be the crap tuner.
Not clear on what you are saying here. Is the idle high or going up and down?
Old Jan 7, 2011 | 09:52 AM
pkozera's Avatar
Up and down after going into closed loop and warmed up. I can unplug the iac when its doing it and it will idle fine plug it back in and after a min or two it will do it again.
Old Jan 7, 2011 | 12:43 PM
3DTIM's Avatar
Sounds like a leak to me. Air getting in. Here is what I have run into. Unplug the IAC and the leak stays the same Idles fine or a little high. Plug the IAC back in and as the leak air is coming in the IAC is trying to stop this so it is chancing to compensate for the leaking air running the idle up and down. When Iran into this it was on my 6-71 witch is a little bet bigger but should be the same. But the tuners on here know a lot more than I do.
Old Jan 7, 2011 | 03:27 PM
blown3qtr's Avatar
That makes alot of sense, but I still think after talking to you it is in the injectors and tune.
cheyenne383
Nov 13, 2015 09:24 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
vmaxpro
Sep 28, 2015 11:10 AM
OHsixLS3
Sep 25, 2015 04:38 PM
