Larger radix intercooler exchanger
Old Jan 4, 2008 | 11:35 AM
  #61
xsports33's Avatar
Originally Posted by BlownChevy
I was just getting ready to call you Hubert, some guy got killed on the 118 the other day and his name and truck description matched yours.....
Glad you are OK!
I heard about that, thankfully it wasn't me. Thanks for lookin out Brian!
Old Jan 4, 2008 | 11:38 AM
  #62
xsports33's Avatar
Originally Posted by 2005SSR6Speed
Your 90mm J-Tube (delivered 01/03/08 @ 6:34pm) and Heat Exchanger should be on your doorstep today. Should be a nice weekend install!
Thanks Joe!!! Awesome turn around time! i got it next day, now's that what i call GREAT customer service. I was all giddy thing morning messing around with it and the 90mm TB that i lost track of time and was late to work I'll probably head home for lunch to get the h/e and bring it out of the rain
Old Jan 4, 2008 | 11:54 AM
  #63
leftcoast32's Avatar
FormerVendor
Glad I could help! Make sure to post up some pictures of the install.
Old Jan 4, 2008 | 12:27 PM
  #64
mine is on order from Joe @ Left Coast (sponsor ----->). It's the heat exchanger for the Caddy cts-v Magnuson part #68-01-00-089. I should be getting it either today or tomorrow and doing the install this weekend. I'm going to move the stock h/e to the lower bumper and put the larger one infront of the radiator and run them in series. Should help me a lot with towing
Are you installing this in a regular 1/2 ton?
If so please let me know if there is any fitment issues.
Old Jan 4, 2008 | 02:35 PM
  #65
BlownChevy's Avatar
blownerator
25 Year Member
Jessie, it is not a "direct" bolt in, there is SOME fabrication required to make it fit.
Old Jan 4, 2008 | 02:47 PM
  #66
I guess what I ment, is that I know that it will fit in a HD frame, now will it fit in a 1/2 ton frame?. I know that it is not a direct fitment, but nothing a sawsaw and hammer cant fix, lol
Old Jan 4, 2008 | 02:52 PM
  #67
xsports33's Avatar
Yeah it's going on a 1/2 ton, it's the truck in my signature. I don't forsee any huge issues ::knock on wood:: but you never know. I've already scoped it out and have a pretty good idea where i'm going to mount everything. I'll take plenty of pictures of the install.
If somethings goes terribly wrong i'll be on a tow bed in front of Magnuson on Monday morning with a case of beer waiting for Brian to show up
Old Jan 4, 2008 | 03:09 PM
  #68
Good luck, Ill be waiting for the pics
Old Jan 4, 2008 | 06:48 PM
  #69
laynlow77's Avatar
Old Jan 9, 2008 | 11:36 PM
  #70
xsports33's Avatar
This heat exchanger is a BEAST!! I moved up the location of the upper bracket to hold the h/e higher up and expose more of it to incoming air. It also fills up the front better and doesn't look as wierd as when it is located a few inches lower.
The view through the driver side tow hook at the lower h/e. I removed the backing to fit the new h/e and have the barb where i wanted it. It also provides more airflow to the lower h/e. I'm debating cutting up my lower fender to get more airflow, but i want to do it in a concealed way. I have to think about that one more and how/if i'm going to do it
I used thru-bolts to secure the bottom of the h/e to the frame. I orignally used self tapping screws, but with the weight of the h/e full of fluid and vibration using thru bolts was definitely the way to go. Much more secure and a lot less worry
The original h/e mounted in the lower fender in series with the larger one
I had to modify the orginal brackerty to fit in the lower fender and angle the way i wanted it to. Made it simiar to the brackets used in the JoeGibbs setup. The bottom h/e is actually mounted and routed the same exact same way as the Gibbs setup except the pump is in the original position, not moved to the lower h/e
Original look with h/e in it's orignal location
