Larger Cooler for my maggie, suggestions?
#22
I used the stock pump and it kept IAT's lower all the time. I was able to add 5 or so degrees of timing at WOT and that gave me several more hp on the dyno. Im thinking 20 rwhp or so.
#23
i got the tank in the rear and i have the mazire pump running the big heat axt. from magg. and a 30x12x4 intercooler up front too but its hard to fight these iat also got meth just waithin on my tunner to use it the diff is that im running a 2.4 pullie oooh i forgot to mention this truck hauls ***
#25
I had the Fluidyne Ford lightning heat exchanger with two 7" fans behind my bumper on my SSS with a Maggie..I also had a 1 gal fuel cell used as a ice box in the orig battery location ..with ice I would see 5-10 degrees below ambient..
#26
As already suggested you can double up your XRs, add fans, add methanol/water injection. A larger or increased XR surface does not keep IAT's down but slows the increase in temp and allows for a faster recovery.
At least this is my personal experience. I use the CTS-V HXR from Magnuson, it's 28x14x1 iirc?
#27
Can you please tell me what your setup is? Pulley size, IATs?
Think it'd be less $ if I went thru Rick? Cause what Maggie direct wants is crazy!
PM sent.
#28
anyone ever look at the nascar, imca coolers and radiators? these are usually thicker but very nice c&r coolers. even if you use the core only and or have to modify the end tanks these things are about 800 new and you can get them for a little over a 100 bucks. just a thought if you got the room
