L33 and turbo boost.
Old Nov 12, 2008 | 10:31 AM
old motorhead's Avatar
Default L33 and turbo boost.
Is there any reason not to go with this engine for a mild intercooled turbo setup (max 6 psi)? Engine will be left stock except for the turbo. Also, what, except for aluminum block and higher compression ratio, is different on this motor to give it the extra power? Seems like the iron block 5.3L is about 25 hp less.
Old Nov 12, 2008 | 10:45 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
No, actually you'd be at an advantage
Heads are better breathing 243/799 casting. Tuning and cam are also different.
Old Nov 12, 2008 | 11:08 AM
Did a little looking around on LS1 tech and it looks like the engine has LS6 heads and a camshaft similar to the LS6 as well. 100 lbs. lighter won't hurt a bit either. Sounds like a neat little motor. Hope it's turbo friendly.
Old Nov 12, 2008 | 11:28 AM
trever1t's Avatar
it is boost friendly I have one in my truck
Old Nov 12, 2008 | 06:46 PM
hog's Avatar
hog
LM7 iron block 9.49:1 cr
L33 alum block 9.9:1 cr
peace
Hog
TAPyvehc93
Jul 23, 2017 10:54 PM
fastjweb
Aug 31, 2015 09:57 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
jaypowe11520
Jul 29, 2015 07:59 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
