KR under light load????
Old May 9, 2007 | 03:28 PM
WJ MARK's Avatar
Default KR under light load????
I did some logging yesterday. Under a light load around 50 mph 2,000 RPM in OD 50-75% throttle maybe 2-3 psi I get some KR. Full throttle from a dead stop through all the gears full bost I don't get any. Any Idea why its doing this?? Can this be bad at crusing speed or should I Haul *** all the time??? lol.
Old May 9, 2007 | 05:29 PM
kbracing96's Avatar
I get that all the time, never been able to tune it out no mater how much fuel I add or how much timing I take out. My thinking is if i can't hear it, and it won't go away, then it's must not be real or important, lol.
Old May 9, 2007 | 05:36 PM
vanillagorilla's Avatar
I get it too, but I thought it was just a 2000 PCM issue. I'm glade to see I'm not alone.
What is your actual timing when the KR kicks in?
Old May 9, 2007 | 05:48 PM
Derek @ EDO's Avatar
FormerVendor
that would be false knock, nothing to worry about!
Old May 9, 2007 | 08:41 PM
03sierraslt's Avatar
I had it as well, but found that tweeking the TCC lockup and unlock points got rid of it. I guess it was putting too much of a load on mine in OD with the converter still locked. I could damn near build full boost before my converter unlocked. All is well now.
Old May 9, 2007 | 10:04 PM
1SlowHoe's Avatar
Destroyer of Transmissions
What are your converter settings? I get almost instant KR of 7* when I give a little pedal when the converter is locked and I am in OD. I have to let completly off the gas to get it back to 0 and then try again.
Old May 10, 2007 | 07:23 AM
KySilverado's Avatar
I have had this all along and have never been able to tune it out. As much as 8* indicated a steady state cruise out of the blue. I have desensatized my sensors a smidge. To the point of still getting a bit from time to time but not so much as to keep my Knock learn going way down.
Old May 10, 2007 | 09:25 AM
WJ MARK's Avatar
yeah I saw up to 7 on mine, It would pull timing back to like 5 deg.
Old May 10, 2007 | 02:30 PM
Later this eve Ill try to post up a screenshot of my TCC lockup/unlock tables.
Old May 10, 2007 | 05:04 PM
1SlowHoe's Avatar
I'd like to see several of you guys post your TC settings and KR sensor values. Just for comparison.
