Kennebell will gmt800 kit fit the gmt900
As for the Throttle body, you can verify without doing anything. Well you may have to take off the engine cover not sure how much it covers. It will either be 3 or 4 bolt.
It depends if you are talking about a side mount or a top mount. Sidemount, yes, I am sure you could make it fit. Topmount, no, unless you plan to swap to a cathedral port head.
If its a side mount and the throttle body on your truck has 4 bolts then you are going to have to do some fabrication. You will have to make a adapter plate for the TB to fit the blower intake Elbow and you will have to make a flange for the blower to intake manifold connection.
