KBracing done did it T6 91mm front mount...
Old 08-18-2010, 09:08 PM
  #21
Swerve7rpm2000's Avatar
Sweeeet Man! Where do i get info for this setup? This might change my mind off the old procharger lol
Old 08-18-2010, 09:10 PM
  #22
11 Second Hall Moniter
AKlowriderZ71's Avatar
Okay, 6 bolts. Jeesh. Forgot "turbo cop" was on duty.....
lol
So how much weight is this KB setup?
Old 08-18-2010, 09:32 PM
  #23
kbracing96's Avatar
Originally Posted by AKlowriderZ71
I've always wondered just how much weight is hanging off of those 8 little exhaust manifold studs with a setup like this, and what are the limits of the studs. Not questioning the strength of the manifold, looks to be quite heavy duty. But at what point should you consider additional support for the weight of the complete assembly?
Actually, there is only 6 bolts, I couldn't find metric specs, but 8mm is pretty much the same as 5/16 and the info I found for a grade 5, 5/16x24 bolt is a shear strength of 5750lbs and a tensile strength of 6440lbs.
Old 08-18-2010, 09:39 PM
  #24
Formerly darynC-10/23/10
Daryn's Avatar
my turbo weighs 19lbs exact. i have not weighed the manifold yet , as im not finished with it yet the only thing i am worried about with a large turbo and nothing to support it but the bolts. is gasket leakage. are you using copper spray on the mls gaskets?
Old 08-18-2010, 09:42 PM
  #25
Okay, Deputy Fife, you didn't answer my question either.
You gotta figure in the leverage of the turbo hanging off the manifold, to calculate if you're getting close to the tensile strength. I'm not smart enough to do the math, but I do understand the concept of leverage & torque multiplication.
Quik's answer of 40 lbs or more needs a support makes sense, and sounds reasonable. I wasn't questioning that, I asked how much the KB setup weighs. (not exact, just approximate)
Old 08-18-2010, 09:44 PM
  #26
kbracing96's Avatar
These turbos are 52.4 lbs. You weren't running a support with you pt88 were you Quik?
Old 08-18-2010, 09:47 PM
  #27
Is the 52 lbs just the turbo, or the turbo, manifold, and DP all added up?
Old 08-18-2010, 09:54 PM
  #28
5 year bitches!
Quik's Avatar
no support with my pig of a turbo. PT88s arent light either and i was using my orignal exhaust bolts
to AZ you got to take into account your DP helps support weight, your cold pipe helps support weight. [if designed right]
Kb's log and my 88 were around 75lbs between the two. my truck deffently noticed the weight on the front spring. however never had issues with any leverage issues. the sch 40 is stout item
now cheaper kits on the market use tube which isnt meant to support weight of large size turbos
Old 08-18-2010, 10:04 PM
  #29
Never had any doubts about the strength of the manifold. Just the bolts at the head. And since everything up here is 4x4, a quick torsion bar adjustment would level everything back out.
Thanks for the info. Some day I may want to build a track truck, might involve a turbo, and I've always wondered about this.
Oh, and Kwik, it's AK, not AZ..... lol
Old 08-18-2010, 10:51 PM
  #30
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
Originally Posted by tarinitup
What gears are you going with? I use 4.10s and boost is almost instant at WOT with same turbo on 408.
3.23 or 3.73 is what i plan on with a 28ISH tall tire
Quick Reply: KBracing done did it T6 91mm front mount...
