Just ordered my new Procharger P-1sc
Old Oct 26, 2008 | 02:54 PM
  #71
Blowndenalixl's Avatar
Any update on this yet? Curious to see if the higher stall wakes up your vehicle like most say it will.
Thanks
SC
Originally Posted by rockerjoe2008
thanks, for the replies. I ordered a 3200 stall this week and should have it installed in the next few weeks. My tuner says they've got the software update they need to tune my truck correctly now. Guess I'll have to wait and see. If I don't like it I'll get blackbear to tune it, because he is with in driving distance from me. I think a spot on tune will really wake my truck up.
cmb570, I have already installed and paid for the the p1, so I am going to try and make it work for me the best I can.
I'm getting ready to drop some more cash on the truck as soon as I can sell some of my other toys. Then the rig is getting long tubes, high flow cats (would go catless but need to pass inspection), electric cutout before the cats, cam and heads, wheels and tires. I should be able to do this all at once when I unload my PA equipment. I think the truck will make some pretty good power after these additions.
Anyone on the restrictor?
Old Oct 27, 2008 | 01:22 AM
  #72
rockerjoe2008's Avatar
Still waiting on the stall to arrive. I'll let you know as soon as I get it installed.
Old Oct 29, 2008 | 12:26 AM
  #73
Got the verter in and plan on installing first of next week and getting my tune fixed. I'll let yall know how it turns out. I still need to post up some pics of the truck, dyno sheet and the install, maybe I'll get around to that by next week too.
Old Oct 29, 2008 | 01:48 PM
  #74
WJ MARK's Avatar
That stall with turn your frown upside down!
Old Oct 29, 2008 | 04:06 PM
  #75
Y2KLimited's Avatar
Is there a way to run a smaller pulley to make more boost sooner but still limit the total amount of boost used? Like a boost controller that will only allow 9lbs to the engine, even if you are actually making, say 14 lbs. Hope this makes sense.
thats pretty much how my truck is setup
Originally Posted by NegraRCSB2X4auto
I've wondered that same thing but never really looked into it.
worth its weight in gold
Originally Posted by jbusmc1986
That is the way that I was going to do it... the other way is to pulley down to like a 14psi pulley, and then put a restrictor on the filter... when you go to the track or any time you want that 14psi just pull the restrictor.
you're going to need a speed density tune, or laptop, cable and 2 tunes loaded into the truck if you're running MAF.
also why the 42 lb injectors......I've seen alot of people run out of injector with them. I have 60's with room to spare. Hell my boosted vette has 60's on it with meth and makes a hell of alot more than the truck with no issues.
Old Oct 29, 2008 | 04:12 PM
  #76
Superado's Avatar
11 Second Truck Club
w/ his setup, I believe 42/44#'ers will be plenty...
now...having said that...w/ old set-up similar to his current one, these were plenty w/ minimal meth...I mean a very small atomizing jet...really small...
w/ new set-up...they're all around 100+ %...w/ ALOT more meth...
Old Oct 29, 2008 | 11:45 PM
  #77
I know of guys building 500hp engines running 42#'ers. I'll upgrade when necessary but I am not close to that point yet.
I've done some research on running a restrictor plate or a waste gate and boost controller. From what I understand that is called overdriving the blower. When you do this it causes a lot of heat and has to be addressed with either a larger intercooler or meth. Since my intercooler is horizontally mounted and I am not ready to add meth I am opting against it for now. I think my next step is I am just going to go with a smaller pulley period and run meth to try and get little more out of the truck.
Old Oct 29, 2008 | 11:48 PM
  #78
Mangled03gmc's Avatar
Baltimore Whore
You will like the stall..
John
Old Oct 29, 2008 | 11:53 PM
  #79
Don't know if I mentioned this or not but the stall is a VIG 3200. I am really looking forward to running the truck with it installed.
Old Oct 31, 2008 | 03:34 PM
  #80
Well @#$% ! My tranny busted yesterday. Only lasted 2,000 miles with the procharger. Now I think it starts off in 2nd and doesn't want to up shift and won't ever go into fourth. Looks like I am going to the dealership and see if they will replace it under warranty, which they probably won't. More than likely I'll be putting a new transmission in a truck that only has 14,000 miles.
