Just got the Maggie done
Old Mar 9, 2010 | 09:53 PM
  #21
3DTIM's Avatar
Thanks a lot.
Now does anybody know the numbers for the wires on the PCM for the cam sensor. Would save me a lot of time. Will pull the wires and check. If they check out OK then pull that new sensor and see if it is OK. Boy pulling that sensor is going to be a real pain. Also did you change the tire size to.
THANKS AGAIN ALLEN
Old Mar 10, 2010 | 09:39 AM
  #22
FarmTruc's Avatar
Performance Trucks Sponsor
A
BRN/WHT
CMP Sensor Signal
PCM: C1 Pin73
B
PNK/BLK
Low Reference
PCM: C1 Pin61
C
RED
12 Volt Reference
PCM: C2 Pin39
C1 is blue
C2 is red
Old Mar 10, 2010 | 07:14 PM
  #23
3DTIM's Avatar
Well worked on the cam sensor all day today. Never did get it out looks like it is just under the chiller and I could not it out. But we did check the sensor and it looks to be good. Looks like the PCM is putting to much voltage to it. 11volts. So hopefully the new tune will clear that up. Thanks Allen for the pin call out.
Old Mar 13, 2010 | 12:24 PM
  #24
3DTIM's Avatar
Well had to pull the blower back off working by yourself is no fun. Left all the water line and anything I could still hooked up. Now on to checking the sensor I have a new one for it.
Old Mar 13, 2010 | 03:58 PM
  #25
3DTIM's Avatar
OK now I am getting mad. three sensors and all show to be good. All show the same code Consecutively High. Plug is good and all wires are good. Anybody know what to do?????
Old Mar 13, 2010 | 04:35 PM
  #26
DrX's Avatar
DrX
"The following conditions may cause this DTC to set:
  • Camshaft reluctor ring damage
  • The sensor coming in contact with the reluctor ring
  • Foreign material passing between the sensor and the reluctor ring
  • Excessive camshaft end-play
  • Wiring routed too close to secondary ignition components "
Did you check that the sensor signal circuit(pin A- BRN/W) is not shorted to 12V?
Old Mar 15, 2010 | 08:40 PM
  #27
3DTIM's Avatar
Here is were I stand. Put a scope on it all wires are good and the new sensor is good. We are getting a pulse from the cam sensor like it should. I well know tomorrow if we are still getting a code. Have the blower off and have to get it all back on and see what is going o with it. Thanks Allen for the offer if all does not go well then I may have to take you up on the offer. One thing does it matter if the motor is an T or Z on the vin?
Edit/Delete Message
Old Mar 16, 2010 | 11:49 AM
  #28
3DTIM's Avatar
Back running same thing. Have not scanned it will as soon as I can get the guy with the scanner back up here. But runs just like it did.
Edit/Delete Message
Old Mar 16, 2010 | 04:10 PM
  #29
3DTIM's Avatar
Scanned it and it keeps jumping from code to code. Whats up with that? First cam code then it said it was misfiring was not then said pedal position was off dose not have that sensor. Then ideal to rich. Well this ever stop!!!!!
Edit/Delete Message
Old Mar 17, 2010 | 05:45 PM
  #30
3DTIM's Avatar
Codes codes codes man this is getting so old.
