Junk yard turbo-anygood??
Old Oct 29, 2007 | 08:53 AM
OnyxSilveradoSS's Avatar
Default Junk yard turbo-anygood??
"Garrett Turbocharger.
.58 a/r on the compressor and .90 a/r on the turbine. The compressor wheel is 61mm and has NO shaft play. Uses a t3/t4 flange."
How would this do on a 6.0L...not shooting for records, low boost is cool, just want my project to have a turbo.
thanks
Old Oct 29, 2007 | 10:45 AM
kbracing96's Avatar
It would probable add some zing to your setup, if that's all your after . There might be better, more suitable turbos, but if the price is right, I'd run it.
Old Oct 29, 2007 | 10:52 AM
vanillagorilla's Avatar
It has a .90 A/R on a T3 housing?
Old Oct 29, 2007 | 11:13 AM
I think its a T4.
What would be "wrong" with this size??? what would the spool and such be good/bad?? would I be out of the map, making it a big heat pump???
The guy wants $200...
Old Oct 29, 2007 | 12:35 PM
Stampede4ever's Avatar
What's it off of? Louds like a decent deal.
Old Oct 29, 2007 | 04:37 PM
older GM diesel, 7.4L, dont know much about older GM diesel sizes.
Old Oct 29, 2007 | 05:41 PM
Default Photo
here is the pic of it.
Old Oct 29, 2007 | 08:07 PM
explorer5.0's Avatar
TOTM: November '07
Can you post a picture of the side of the turbo. It almost looks like a VNT turbo off of a 6.0 Powerstroke which would be garbage for any non 6.0 PSD application.
Old Oct 29, 2007 | 08:10 PM
Hope this helps-thanks
Old Oct 29, 2007 | 08:13 PM
TOTM: November '07
Yep, thats what it is- a 6.0 PSD turbo. It could work, but your have to find a way to control the VNT. Basically it is more trouble than its worth.
