J-tube on a radix, before or after?
Old Apr 16, 2008 | 09:41 AM
BigCountryx's Avatar
Default J-tube on a radix, before or after?
The directions say put the j-tube on before you install the blower, but I've been told it is easier to instal after, what do you guys think?
Also, where does the tubing from the botom of the EVAP run to? The back of the J-tube?
Old Apr 16, 2008 | 10:14 AM
bpowell688's Avatar
IMO dude i would leave the j tube on and it sould fall rite in to place..
When i did mine it did..
and the EVAP line sould run to the side the J tube..
Old Apr 16, 2008 | 10:20 AM
BlownChevy's Avatar
blownerator
25 Year Member
The blower should come with the J-Tube installed. If you are installing a different J-Tube then yes, do it before you install the blower.
Old Apr 16, 2008 | 11:06 AM
Cool, I'll try that first, lol
There are 3 barbs on the rear of the J-tube. I take it one of these are for the bottom Evap Hose?
Thanks Again guys.
Old Apr 16, 2008 | 11:14 AM
Stoichiometric's Avatar
No, the evap plugs into the hole on the front of the lower manifold.
Old Apr 16, 2008 | 11:15 AM
thunder550's Avatar
High on diesel fumes
The evap canister should mount to the front of the blower. The ones on the back are for the brake booster and other vacuum lines.
Old Apr 16, 2008 | 11:17 AM
bpowell688's Avatar
and the bottem of the evap theres a hose it sould go to the side of the j tube..
Old Apr 16, 2008 | 11:18 AM
I forgot about that one!
Old Apr 16, 2008 | 11:27 AM
That's the one...thanks
Old Apr 16, 2008 | 01:40 PM
BLASTER's Avatar
Do it before. I just pulled my blower off to install the J tube. Not see how I could have done it otherwise.
