Issues with MAF and boost
Old Jul 21, 2018 | 05:24 PM
TAPyvehc93's Avatar
Default Issues with MAF and boost
Just wanted to see who all is successfully using a MAF with boost. I'm I'm having issues with my truck starting off rich at the beginning of a pull and then being lean at the end of a pull because my MAF hertz is reading 13500 at 5500 rpm and by 6300 it's still around 13500 hertz so it's not getting anymore fuel with more rpm. It's a 2011 GMC with a trick turbo stage III
Old Jul 27, 2018 | 02:42 PM
RySmDPT14's Avatar
Is that the max of your MAF? I have 2012 and my max is 16000 and I’ve only hit that at 15lbs boost. Try scaling it or consider SD?
Old Jul 29, 2018 | 02:01 PM
TAPyvehc93's Avatar
Nope, not maxed out. Mine is the same as yours. Its just not reading much of a airflow change from around 5600-6300 rpm. It kind of just hovers around 13500 hertz.
Old Jul 29, 2018 | 02:04 PM
RySmDPT14's Avatar
post your log and tune, if ya can.
Old Jul 31, 2018 | 06:29 PM
TAPyvehc93's Avatar
Heres a log of a little pull I did today. Skip to frame 16:18:39. You can see when its at 5300 rpm and 13500 MAF hertz the AFR's are around 10.5:1 and when its at 6200 rpm its still reading 13500 MAF hertz but now its reading around 11.5:1 AFR.
File Type: hpl
Old Jul 31, 2018 | 06:32 PM
TAPyvehc93's Avatar
I was thinking about maybe trying a airflow straightener before the MAF if that's even possible with a card style maf?
Old Jul 31, 2018 | 06:48 PM
TrickTurbo's Avatar
Truck Sponsor
what point is the maf maxed out?
Old Jul 31, 2018 | 06:53 PM
RySmDPT14's Avatar
I see how it just hovers around 13500 hz. in your log 5000rpm to 6192, try raising MAF fail HZ. to 16000, as well as maf correlation to 8000 rpm, and codes p101, 106 and 121 to 256F and 257f
Old Jul 31, 2018 | 06:54 PM
RySmDPT14's Avatar
should max out at 16000hz
Old Jul 31, 2018 | 06:58 PM
TAPyvehc93's Avatar
The MAF isn't maxed out Rick.
