Interesting find with meth injectors
Old Apr 30, 2009 | 09:55 PM
2ktransam's Avatar
Default Interesting find with meth injectors
One of the problems I found on my truck was a massive boost leak from a meth injector that was unplugged. I assumed that they were one way like a check valve so I have been running around with one unplugged and it was making my truck really laggy. I pressure tested my pipes before I went to the track the other night and I couldn't even build pressure in the pipes due to the bleed off from the meth injectors. I put a plug in that hole and then the meth jug started to bubble from the pressure bleeding through the injector that was hooked up. Once the meth kicks on this isn't a problem but it does slow spool up because of the leak. I am going to call Snow and see if they can do anything to help with this issure.
Old Apr 30, 2009 | 10:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
interesting, keep us posted on the response!
Old Apr 30, 2009 | 11:15 PM
MFIC's Avatar
Save yourself the trouble of calling Snow I'm pretty sure they don't have check valves and get the 1/4 tube to 1/4 tube and throw it inline before the nozzle. https://www.alcohol-injection.com/wa...valves-64.html
Old May 1, 2009 | 07:39 AM
2ktransam's Avatar
Thanks for the tip. Can I make that work with the Snow injectors or would I have to order Devil's Own injectors?
Old May 1, 2009 | 07:53 AM
Rick_Vor's Avatar
Like MFIC mentioned, just by the 1/4" push-lock to 1/4" push-lock and splice it anywhere into the 1/4" red plastic tubing.
Rick
Old May 1, 2009 | 12:38 PM
2ktransam's Avatar
Rick
That sounds easy enough. Thanks
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
MS3Z
Jul 30, 2015 06:17 PM
black6spdz
Jul 16, 2015 01:32 AM
