Intercooler pump
Old Feb 11, 2008 | 10:59 AM
zippy's Avatar
Default Intercooler pump
While working on a friends 2004 2500 with a Radix on it I found that the intercooler pump had failed. After some re-search I figured I'd try something different. I ordered a GM pump #10449179 which is a pump used on Venture vans for the rear heater core. Not only is the pump smaller with a much nicer and cleaner mounting system, but it also has the same connector as the stock Magnacharger pump. After installing it and driving around I found the IAT's seem to fall quicker with this pump than they did with the original. I was wondering if anyone else has tried this?
Old Feb 11, 2008 | 11:49 AM
TrickTurbo's Avatar
Truck Sponsor
pics of pump.
Old Feb 11, 2008 | 04:05 PM
zippy's Avatar
I'll have to try to get a picture of one later this week.
Old Feb 11, 2008 | 04:37 PM
OnyxSilveradoSS's Avatar
Borat voice " VERY NICE"
Old Feb 11, 2008 | 05:06 PM
dewmanshu's Avatar
Moderately Differentiated
I love anything that messes up a "package" and turns out nicer!
I am sure maggy did their research, IAT's come down quicker, how do they look on the climb?
Old Feb 11, 2008 | 05:15 PM
ramsey rider's Avatar
ive always wondered if another kinda pump would work better.ive been 2 nervous that if i ordered something with too much pressure it might screw up the expensive intercooler setup i have .whats the thought on this and what kinda pressure would the int ,cores take?i mean the 1 i got with my kit u can barely tell its circulating.i would think that alittle more pressure might not be a bad thing for cooling.
Old Feb 11, 2008 | 05:36 PM
03sierraslt's Avatar
The key is finding a happy medium, if it circulates to fast then it cant absorb the heat and if its too slow then it cant transfer the heat away fast enough.
Old Feb 11, 2008 | 05:38 PM
dewmanshu's Avatar
exactly! There's a chevy performance article floating around here somewhere that found by decreasing the voltage a cooter hair you got the best results.
***EDIT*** Here it is LINKY
Old Feb 11, 2008 | 05:45 PM
Setup the voltage on a adjustable gain and just play with it to find what works the best....
Yaaa just play with it Dewey....
Old Feb 11, 2008 | 09:14 PM
CHarris's Avatar
Sounds cool What are the hose fitting sizes on that?
