Intake for a procharged setup
Old Sep 9, 2010 | 06:37 AM
sureshot's Avatar
Default Intake for a procharged setup
I have been kicking around the idea of changing my intake setup over this coming up winter. I have read alot of conflicting information. My question is, would I benefit from a Fast 92 or 90 setup, or a vic jr setup? My setup is pretty much in my sig. Any thoughts or suggestions would be appreciated.
Old Sep 9, 2010 | 09:42 AM
ls 2 goat's Avatar
Vic jr is gonna make less power in the lower RPM range and more power in the higher RPM range than a FAST. You need to make a choice on low end vs high end and roll with it.
Old Sep 9, 2010 | 10:06 AM
sharpshooter's Avatar
I've heard the low end loss on the jr. was seen with the carb. set-ups and not the injected set-ups.
Is their any truth to this?
Also his stall flashes to 3000 rpm's if that adds some more info.
Old Sep 9, 2010 | 06:35 PM
sureshot's Avatar
I read somewhere on pt.net that the vic jr. makes power from 1800-7500 on EFI applications. The 3500-7500 rpm range was for carbureted applications. I know Quik swore his 90mm FAST made power even out of boost.
Old Sep 10, 2010 | 09:13 AM
Bad_Apple's Avatar
Im running a Fast 90 and have been really happy with it...
Old Sep 10, 2010 | 09:32 AM
sureshot's Avatar
Are you running a larger TB as well? Did you notice gains across the whole power band, or just up top?
D1SCSS
Jan 25, 2016 10:14 PM
The_W
Oct 28, 2015 09:00 PM
Aboss
Aug 11, 2015 09:05 AM
Ketis
Jul 23, 2015 12:37 PM
