installing a tvs1900
Old Oct 29, 2011 | 09:08 PM
05 vortec high output's Avatar
Default installing a tvs1900
going to install a tvs1900 on a 05 gmc sierra vho with pacesetters no cats, going to install a " CheaTR v.3" - 219/230 .607/.604 117 LSA cam, 7.425 pushrods, ls6 oil pump, Precision Race Components .650" Double Spring Kit,160º degree Thermostat,
saving up money to buy a built trans, n converter,
told me i should get a 2800 stall, and thinking to buy a PerformaBuilt Transmission,
i also wanna raise the boost. i need help with injectors and fuel system,
pulleys, and a tune,
thanks for yall help
Old Oct 29, 2011 | 09:36 PM
03sierraslt's Avatar
Was there a question in there somewhere?
Old Oct 29, 2011 | 09:46 PM
jrmchevyman's Avatar
depends on how much boost you want to run. Id say get 60# injectors and walbro 255. You can make do with less, we don't know how much boost you are wanting to run. All you said was "I wanna raise the boost."
Also you really don't need to upgrade the thermostat, the stockers work fine and the stock oil pump is fine as well unless it has a ton of miles on it and you were going to be changing it anyway.
Old Oct 29, 2011 | 10:40 PM
how much boost are they capable of?
Old Oct 29, 2011 | 10:42 PM
is a 2800 stall good enough
Old Oct 29, 2011 | 11:46 PM
TX Tahoe Z71's Avatar
should be perfect. Check Circle-D 278mm ones.
Old Oct 29, 2011 | 11:54 PM
jiar577's Avatar
More than what your engine will handle
Unless it's built of course...
Most people here shoot for 10-11psi on stock bottom ends, spraying some meth helps too.
Old Oct 30, 2011 | 07:10 AM
Who does a good mail in order tune?
Old Oct 30, 2011 | 07:11 AM
Where can I buy the pulleys for the tvs1900
Old Oct 30, 2011 | 07:13 AM
I am thinking to buy a performabuilt trans. Any one buy some already any advice on the built trans. Thanks
