inline pump always on?
Old Mar 30, 2008 | 02:43 PM
350SS's Avatar
Default inline pump always on?
I'm trying to decide how to upgrade my fuel system and don't know the answer to some easy questions.
I'd like to add an inline pump to the existing system but don't really care for how loud they are. My first questions is if you place a pump in series with the factory one like most guys do (see below), is it always running or only under boost?
Old Mar 30, 2008 | 03:06 PM
thunder550's Avatar
High on diesel fumes
Return style fuel system? Always running....pressure is determined by the regulator on the fuel rail.
Old Mar 30, 2008 | 03:21 PM
350SS's Avatar
This is a return style fuel system. I guess the only way to have a second pump that is only on under boost is to go with a dual in-tank or possibly a parallel system rather than series?
Old Mar 30, 2008 | 03:40 PM
thunder550's Avatar
Twin in-tank with a Hobbes switch will do it. I have twin 255's, the second one comes on a 4psi. I get almost 70 psi fuel pressure through the stock lines, crossover, and rails
Old Mar 30, 2008 | 04:50 PM
kbracing96's Avatar
You could do a semi parallel system I think if you put a Y right after the fuel filter and then one into the pump and one into a check valve, so there is no way for the extra flow from the second pump could "push back" to the stock pump. then just have the external pump on a pressure switch to come on with boost. Should work as well as a series setup with the stock pump being the flow restriction, but with the pressure being divided between the two pumps when in boost, it would flow more then when the stock pump was carrying the system on its own. Just an idea.
Old Mar 30, 2008 | 05:00 PM
TG02Z71's Avatar
Just asking here beacause I think it's relavant, doesn't the in-line pump NEED to be on or issues will arise?
If the in-line is off is there not a restriction pushing through it with a single in-tank stock pump? Just asking beacuse it has been explained this way in the past to me.
Old Mar 30, 2008 | 05:30 PM
MikeGyver's Avatar
Originally Posted by kbracing96
You could do a semi parallel system I think if you put a Y right after the fuel filter and then one into the pump and one into a check valve, so there is no way for the extra flow from the second pump could "push back" to the stock pump...
I was having the same thought, except I think you would need a solenoid valve instead of a check valve.
Old Mar 30, 2008 | 05:57 PM
350SS's Avatar
This is pretty much what I had in mind with regards to a parallel setup. I'm just wondering if it's easier/cheaper to go this way or to build a twin intank setup. I haven't been able to find a check valve setup that I would feel safe running for fuel that isn't $$$.
Old Mar 30, 2008 | 05:59 PM
350SS's Avatar
That's what I would assume but never really heard anyone discuss it specifically.
Old Mar 30, 2008 | 06:00 PM
350SS's Avatar
Hmmm, a solenoid valve that would open when the 2nd pump turns on? Or would it close the side without the pump and switch to run the pumps in series?
