Injectors
Old Oct 5, 2012 | 11:52 AM
nonnieselman's Avatar
Default Injectors
Just got my injectors from FIC.. and found out they are only 60# at 58psi.. thats not gonna support too much power is it?
Old Oct 5, 2012 | 12:04 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
~700 hp at the crank with conservative assumptions (0.65 BSFC, 80% max duty cycle)
If you loosen up the assumptions a bit (.60 BSFC, 95% max duty cycle), 875 at the crank.
Personally, I'd rather use the conservative assumptions and have a bit of a safety net, than the opposite.
(and before anyone says that the BSFC numbers are too high, Jonathon is going turbo)
Old Oct 5, 2012 | 12:26 PM
So you say they are enough for 600hp?
My buddys truck has a stock 5.3, isky 212/.561 114 cam, magnum 76mm. And on 15psi he is at 85% IDC with 73# injectora. I was hoping to go 12-13psi on the LQ4.
Ill be runnin a D010, D014, and a D07 nozzle. So 32 gph of methanol.
Think it will be ok?
Old Oct 5, 2012 | 12:29 PM
Plus these 43.8# injecotors i have in here now are at ~105% on 5 psi
Old Oct 5, 2012 | 01:04 PM
lownslo's Avatar
i ran fast 57#'s, do you have any of my old logs? I know I went to 10psi on those and made 551/594 with plenty of injector left.
Old Oct 5, 2012 | 01:14 PM
idahoblkss's Avatar
youll have plenty of injector as long as your running pump fuel , e85 would be cutting it close
Old Oct 5, 2012 | 01:25 PM
ive had a jump drive die and a computer crash.. i dont have much of my old stuff..
Im runnin 93 oct and Sunoco M2? 98% methanol
Old Oct 5, 2012 | 01:34 PM
idahoblkss's Avatar
what pump you running? cause those injectors should out flow a 255 at least my 60's out flowed my 255 walbro. i had to go dual pump to push my 60's full capacity , this all on e85 of course.
Old Oct 5, 2012 | 01:37 PM
lownslo's Avatar
nonnie, I think there are some logs in a email from me and you and justin. Check there. on 7psi we did a bunch of logs. If you have old emails, I will look and see if I can find them if you don't have them...... if you think it will help you.
Old Oct 5, 2012 | 01:38 PM
Boober's Avatar
I have those same exact injectors and I am at 95%+ IDC @8psi with Whipple on a stock 6.2. Granted, I'm returnless and my actual rail pressure at WOT is more like 49psi.
